F2 issue
Old Oct 30, 2007 | 11:53 PM
wheelie_chris's Avatar
Default F2 issue
check it out. I just took a 91 F2 off my friends hands that has been sitting in his backyard for about 5 yrs.
Now I got it to start, My problem is the bike seems stiff. here is an example when I get on it to push it forward or back it is really hard not smooth, seems like the brakes are stuck but i checked them and they are ok. can it be the chain from sitting so long. it is kind of rusted, is this a possibility.? any Ideas?
Old Oct 30, 2007 | 11:56 PM
undercoverbrother's Avatar
Default RE: F2 issue
5 years sitting outside?garage?.. in either case it will feel stiff. things will need replacing...some might just do fine with some lube.
Old Oct 31, 2007 | 12:04 AM
Another thing... When I take it for a ride around the block it loosens up then the next day it gets hard again. [:@]
Old Oct 31, 2007 | 12:46 AM
Sand.Man's Avatar
-bearings?
-brake lines/fluid expanding after a short ride (loosening up) then contracting overnight (tightening)? (also known as brake fade)
-clutch dragging? replace oil and adjust lever
-maybe rusty/kinked/worn out chain? buy motul "road" chain clean and lube and freshen it up
all I can think of right now, check those out and tell us what happens
Old Oct 31, 2007 | 11:27 AM
Thanks, I will check it out!
Old Oct 31, 2007 | 05:17 PM
Acara1796's Avatar
It's been sitting for 5 years outside. I would be change all fluid, chain, tires, brake lines, rebuilding all calibers and changing the forks seals and dust covers.
Just funny that way.
Sprock
Jan 16, 2014 09:15 PM
Nos325
Jun 28, 2013 07:32 AM
markybwoi
Apr 11, 2011 11:35 AM
Snoman
Mar 11, 2010 11:47 AM
StangLou
Sep 1, 2007 08:49 AM
