F2 Gas mileage? MPG and Range
#21
RE: F2 Gas mileage? MPG and Range
ORIGINAL: eweppley
That's funney FNQuick. From your picture, your tank looks just like mine does as it sits on the bike. I put well over 3 gallons in mine all the time though. Huh????? I'm mystified....
RB
#22
You know ...I never reallynoticed. When Ibought her, I ran her until I had to go on reserve to see when I should start looking for gas. She started cutting out at around 165 miles on the trip meter. From then on, I've just tried to fill the tank between 150-160 miles.
My Clymer service manual gives the capacity at 4.23 gal. with the reserve being 0.8 gal of that. I guess I do only put a little over 3 gal. in it at the pumps.
Might California models have smaller tanks for some reason?
#23
ORIGINAL: eweppley
No,our bikes allshare the same size gas tank, 4.2 gallons. Some of you just fill it a little sooner than is needed. There is nothing wrong with that. Pushing a bike with no fuel is not much fun.
I can get nearly 200 miles from a tank, but I usually fill up around 165 miles, that is two and a half days of commuting for me. On the safe side I figureI get 40 mpg, thoughI know I actually get 52.
#24
#25
There isn't a three gallon tank. As FNQuick said, at the top of the hump where it looks like the fuel has been used from the main part of the tank it will take 3 gallons. On my bike I can easily go 3 inches or so below that point before reserve. IIRC, i put 3.7 gallons in it last year without hitting reserve and 3.9 gallons about 4 miles after hitting reserve once.
Anyway, I normally fill up at 145 miles and my mpg averages between 40-45 depending on how new the oil is.
#26
#27
150miles before i hit reserve and that is good for about another 15-20 (don't ask how i know that) but avg 45mpg 91 octane or better, k&n filter, and a vance and hines slipon, with saddle bags, and if i am lucky that day, my girlfriend[sm=happybounce.gif]
#29
#30
Krokus, that is about what I figured for the fuel tank. I can get over 3.5 gallons in mine without hitting reserve, but I always get it to the top of the fill area, almost to the point it overflows. I just feel bad about using a cc for a $12 gas purchase and want to get the most miles before I fill up again.
