F2-F3 interchangability
Old Jan 17, 2008 | 02:38 PM
  #21
black_98civic's Avatar
Default RE: F2-F3 interchangability
ORIGINAL: kjohnson
and a 97-98 will fit but it is a wider rim than the others
Nope.All F3 rear wheels are the same width (5.0 inches).
alright. that's what i was trying to figure out as i want the 5.0 inch wheel
Old Feb 6, 2008 | 07:09 PM
  #22
SpecR's Avatar
What's the final verdict on the F3 upper fairing with F2 lowers, if you change the headlight?
Old Feb 7, 2008 | 03:50 PM
  #23
rider0033's Avatar
ORIGINAL: bindelsf2
[align=left]i found this on a different forum and spent a little time and updated it thought it would be usefull.[/align][align=left][/align]Front Rim: No—speedo is different
Front fender:no
Front Rotors:no
Front Calipers:no
Front axle: ?
Forks: interchangeable, but not direct bolt on
Clip-ons: yes
Clip-on controls (start switch, etc.):Yes
Clutch/Brake lever:Yes
Front brake reservoir: yes
Front brake lines: yes
Front Fairings: yes
Front bracket stay:No
Headlight:No
Turn signals:Yes
Triple tree:yes 91-96, 97-98 diff
Mirrors:Y, but different
Guages: Y, but different wiring
Wiring harness: ?
CDI box: no
Frame: slightly different.
Frame sliders: yes
Radiator: no
Carbs: different b/n f2 & f3
Air box: different b/n f2 & f3
Coils: yes but different
Engine:Yes, but different
Oil Pan: No
Stator cover:Yes
Clutch cover:Yes
Side fairings:Y 91-98
Inspection doors:yes, if you change to F3 fairings
Gas tank:Yes, have to change petcock
Petcock:No
Seat: Y 91-96;Y 97-98
Rearsets: yes
Kickstand: yes
Subframe:Yes
Passenger rearsets:Yes
Side/tail fairings:Y 91-96 diff 97-98. have to change seat and taillight too
Rear shock:Y, f4 andf4ifit too butdifferent
Taillight: 91-96; 97-98. have to change side tail
Coolant bottle: yes
Thermostat/Radiator hoses: yes
Front sprocket cover: yes
Front/Rear Sprockets: yes
Swingarm: NO
Rear fender: ?
Rear rim:Y, butdifferent F2 was 4.5” F3 was 5.0”
Rear Axle: Yes
Rear rotor/rear brake:Yes
Muffler/Exhuast:no.midpipes diff size
Headers: yes
windscreen- no
Clutch-yes
note: 95-96 & 97-98 are nearly identical except for:
- tail fairings
- seat
- tray
- tail light
- swingarm
-97-98 5.0” rim[align=left][/align]
nice list and research
Old Mar 3, 2008 | 03:21 PM
  #24
jonblaze's Avatar
subscribing
[/align]subscribing
Old May 11, 2008 | 07:28 PM
  #25
Dj_Squatch's Avatar
Im confused...so would this fit my f2? http://www.ronayers.com/catalogs/pu/...89&type=33
Old May 27, 2008 | 03:12 PM
  #26
rk97's Avatar
can someone clarify on things that are "yes, but not the same."
Am I to take that as, yes you can swap them without issue - they're just not identical pieces?
as in, if I were to buy an F2 with a blown engine, I could buy an eBay F3 engine and not have any fits installing it?
Old May 29, 2008 | 10:52 AM
  #27
drpitlo's Avatar
Correction for the front wheel on a f2 To fit a f3 it will work on the f3 u just have to use the speedometer spacer from the f2. I just bout a 94 f2 parts bike that had chrome wheels and it fit on my 96 f3 didnt have to change the calipers,rotors or forks.
Old May 29, 2008 | 10:57 AM
  #28
drpitlo's Avatar
Also for DJ S the upper triple tree clamp should work on a f2 i swapped over the triple tree clamp from the f2 to my f3 and they were identical.
Old May 31, 2008 | 02:24 AM
  #29
horsboel's Avatar
What is different from the f2 bare engine to the f3. I was hoping that you could buy a bare f3 enigine and fitit to the f2 chassis
and useallthe f2 things to make itrun again.
Old Jun 2, 2008 | 09:38 PM
  #30
rk97's Avatar
if anyone was interested in the F2/F3 engine swap, it was answered here https://cbrforum.com/m_578864/tm.htm
