F2-F3 interchangability
i found this on a different forum and spent a little time and updated it thought it would be usefull. Front Rim: No—speedo is differentFront fender:no Front Rotors:no Front Calipers:no Front axle: ? Forks: interchangeable, but not direct bolt on Clip-ons: yes Clip-on controls (start switch, etc.):Yes Clutch/Brake lever:Yes Front brake reservoir: yes Front brake lines: yes Front Fairings: yes Front bracket stay:No Headlight:No Turn signals:Yes Triple tree:yes 91-96, 97-98 diff Mirrors:Y, but different Guages: Y, but different wiring Wiring harness: ? CDI box: no Frame: slightly different. Frame sliders: yes Radiator: no Carbs: different b/n f2 & f3 Air box: different b/n f2 & f3 Coils: yes but different Engine:Yes, but different Oil Pan: No Stator cover:Yes Clutch cover:Yes Side fairings:Y 91-98 Inspection doors:yes, if you change to F3 fairings Gas tank:Yes, have to change petcock Petcock:No Seat: Y 91-96;Y 97-98 Rearsets: yes Kickstand: yes Subframe:Yes Passenger rearsets:Yes Side/tail fairings:Y 91-96 diff 97-98. have to change seat and taillight too Rear shock:Y, f4 andf4ifit too butdifferent Taillight: 91-96; 97-98. have to change side tail Coolant bottle: yes Thermostat/Radiator hoses: yes Front sprocket cover: yes Front/Rear Sprockets: yes Swingarm: NO Rear fender: ? Rear rim:Y, butdifferent F2 was 4.5” F3 was 5.0” Rear Axle: Yes Rear rotor/rear brake:Yes Muffler/Exhuast:no.midpipes diff size Headers: yes windscreen- no Clutch-yes note: 95-96 & 97-98 are nearly identical except for: - tail fairings - seat - tray - tail light - swingarm -97-98 5.0” rim |
RE: F2-F3 interchangability
Nice. I was hoping the front rim would work. Oh well.
BUMP!
What do you have to do to use F3 forks, exactly? |
F3 forks must have with them in order to work:
F3 fender \ F3 wheel > ---- These 3 must go together,these are not interchageable with F2 F3 calipers / front end parts Exceptions are listed below*. I recommend using an F3 lower triple clamp when doing this changeover *Now,you can use F3 internals in F2 forks,with some small modifications to the F2 dampening rod uppers.All cartridge uppers will swap. *The F3 fork leg uppers and internals will fit F2 fork leg lowers. Make sure you use new seals when re-doing suspension.Use OEM seals,they are the best. |
I'm going to start building an F2 from the ground up. Bare frame that is.
I'd rather use all F3 parts if possible, but does anybody know what F2 parts I'd HAVE to use? |
front fairings dont fit boss. gotta change headlight along with fairings
Will the rear tire hugger from a 97 f3 fit a 94 f2?
so 95-96lower and tail fairings will fit on a 94 F2 with out having to change any other parts, but if you wanted to use the 97-98 on a 94 f2, you'd need a new seat and tail light?
i dont know about the lowers but i know that the tail will, thats what i have on my bike and yes you would needa seat,taillight and taillight bracket
I was looking over that list and learned a lot. My input: I am quite certain that the wiring harnesses are different. The CDI box has different number of pins and F2 has no elec fuel pump.
| All times are GMT -5. The time now is 03:24 AM. |
