F2-F3 interchangability
i found this on a different forum and spent a little time and updated it thought it would be usefull.
Front Rim: No—speedo is differentFront fender:no
Front Rotors:no
Front Calipers:no
Front axle: ?
Forks: interchangeable, but not direct bolt on
Clip-ons: yes
Clip-on controls (start switch, etc.):Yes
Clutch/Brake lever:Yes
Front brake reservoir: yes
Front brake lines: yes
Front Fairings: yes
Front bracket stay:No
Headlight:No
Turn signals:Yes
Triple tree:yes 91-96, 97-98 diff
Mirrors:Y, but different
Guages: Y, but different wiring
Wiring harness: ?
CDI box: no
Frame: slightly different.
Frame sliders: yes
Radiator: no
Carbs: different b/n f2 & f3
Air box: different b/n f2 & f3
Coils: yes but different
Engine:Yes, but different
Oil Pan: No
Stator cover:Yes
Clutch cover:Yes
Side fairings:Y 91-98
Inspection doors:yes, if you change to F3 fairings
Gas tank:Yes, have to change petcock
Petcock:No
Seat: Y 91-96;Y 97-98
Rearsets: yes
Kickstand: yes
Subframe:Yes
Passenger rearsets:Yes
Side/tail fairings:Y 91-96 diff 97-98. have to change seat and taillight too
Rear shock:Y, f4 andf4ifit too butdifferent
Taillight: 91-96; 97-98. have to change side tail
Coolant bottle: yes
Thermostat/Radiator hoses: yes
Front sprocket cover: yes
Front/Rear Sprockets: yes
Swingarm: NO
Rear fender: ?
Rear rim:Y, butdifferent F2 was 4.5” F3 was 5.0”
Rear Axle: Yes
Rear rotor/rear brake:Yes
Muffler/Exhuast:no.midpipes diff size
Headers: yes
windscreen- no
Clutch-yes
note: 95-96 & 97-98 are nearly identical except for:
- tail fairings
- seat
- tray
- tail light
- swingarm
-97-98 5.0” rim
F3 forks must have with them in order to work:
F3 fender \
F3 wheel > ---- These 3 must go together,these are not interchageable with F2
F3 calipers / front end parts
Exceptions are listed below*.
I recommend using an F3 lower triple clamp when doing this changeover
*Now,you can use F3 internals in F2 forks,with some small modifications to the F2 dampening rod uppers.All cartridge uppers will swap.
*The F3 fork leg uppers and internals will fit F2 fork leg lowers.
Make sure you use new seals when re-doing suspension.Use OEM seals,they are the best.
F3 fender \
so 95-96lower and tail fairings will fit on a 94 F2 with out having to change any other parts, but if you wanted to use the 97-98 on a 94 f2, you'd need a new seat and tail light?
i dont know about the lowers but i know that the tail will, thats what i have on my bike and yes you would needa seat,taillight and taillight bracket
I was looking over that list and learned a lot. My input: I am quite certain that the wiring harnesses are different. The CDI box has different number of pins and F2 has no elec fuel pump.
