F2 Carb Cleaning
Old 08-20-2008, 03:28 PM
Rickracer's Avatar
Default RE: F2 Carb Cleaning
Just so you know, you dont read the ground strap, you need to read the porcelain. It looks lean too though. Id open up the pilot screws a bit and see what happens. [8D]
Old 08-20-2008, 06:59 PM
Well I have read quite a bit on how to read spark plugs and discussed this with racers and tuners both here and in the states. Now some say that the porcelain will not tell you a thing, can be white as a bone and still be to rich, others say that the porcelain tells you how the midrange is. I have been tuning and racing for quite a few years now and have found that the porcelain is a good indication on the midrange, but saying that now that I have the F3 carbs in with the ram air system I am not getting as good of a reading on the porcelain as I did.
There are many things to consider when reading spark plugs for example how deep in to the plug the shoot is going.
Old 08-21-2008, 09:15 AM
Rickracer's Avatar
In order to get an accurate read, you need to operate in the range you wish to calibrate for for at least a few seconds, then kill the motor in that range. For instance, if you wish to know the fuel mixture @WOT, then kill the motor clean at the endof a 1/4 mile run.If one isonly wishing to know a general overall, then I'd suggest pulling and read all the plugs after a normal ride. Plug reading is an inexact science at best, but it's cheap to do, and can be quite successful with some practice. [8D]
Old 08-22-2008, 11:00 AM
Chris07's Avatar
Actually you don't read the porcelain you read the base ring.But it’s all irrelevant, as you really can’t read plugs these days. I have jetting many quads and bikes and never got it right with out a dyno and AF gauge. I have a KFX700 quad that will blacken plugs when its lean. 14:1 – 15:1 and the plugs will be black.
http://members.uia.net/pkelley2/sparkplugreading.html
sk8er406
F2 Tech
08-08-2011 10:44 AM
gruntworker
09-02-2009 03:14 PM
IpilotU264
10-29-2007 01:58 PM
mingstah
06-18-2007 05:48 AM
plastikmelter
12-18-2005 11:20 PM
Quick Reply: F2 Carb Cleaning
