engine swap help...
Old Mar 5, 2007 | 11:13 PM
328citony's Avatar
Default engine swap help...
Hi every one, I just bought a 92 f2 and I want to turn it to a project bike. I want to put a 900cc engine in it I heard about it and such but what all do you need to get this up and running.
What type or year engine is needed. does the trans have to be swap, what kind of motor mounts.. ect
please help!!! Thank you
Old Mar 5, 2007 | 11:19 PM
bindelsf2's Avatar
Default RE: engine swap help...
do a search there is a brief write up from when i did it.
i thought it was a pain in the a$$.. the engine and trans have to be swapped. F2 upper and lower mounts will have to be cut and a new lower welded in.. use the 893cc engine. you will have to loose the airbox. one sec i will find the write up.
this is all that i had to go by. http://home.insightbb.com/~cbr600f3/but DONT notch the frame. 2 months after this i read that his frame cracked through. shave the head off the acorn nut its easier. anything else let me know.
Old Mar 5, 2007 | 11:28 PM
bindelsf2's Avatar
https://cbrforum.com/m_94492/tm.htm
https://cbrforum.com/m_175503/tm.htm
oh yeah and the first time i took it out the motor mount ripped off the block and its aluminum so the engine had to be taken apart and 200.00 to weld the ear back on. and it HAD to go to the shop to be tuned and they were mystified by trying to tune it with no airbox.(the f2 is too small and the 900 airboxwith the f2 tank is too big) that cost me 600.00 and that was with my 15% club discount.
Old Mar 6, 2007 | 02:22 PM
328citony's Avatar
How much total did you spent on this conversion? bindelf2..
Old Mar 6, 2007 | 03:01 PM
bindelsf2's Avatar
prob close to 2000.00
engine-500 (which wasa "hook-up")
tuning-600 had to go in twice at 300.00
pipe and headers-350.00
welding the engine mount- 200.00 only because it broke- the rest i did myself.
odds and ends--100.00
new radiator hose-20.00
i think that was everything.
Old Mar 6, 2007 | 08:56 PM
rsp919's Avatar
CBRF 2009 AOTY !!
98 919cc motor $600
D@D header $150
radiator hose $ 15
UNI ind. air filters$ 45
tuning and dyno$200
welding case of beer
look on the guys face on the r1 when you fetch him, PRICELESS
Old Mar 6, 2007 | 09:42 PM
bindelsf2's Avatar
theres the other sleeper! long time no see.
Old Mar 6, 2007 | 11:03 PM
rsp919's Avatar
CBRF 2009 AOTY !!
Yeah, been awhile.I don't know if you seen my other post butI did vote for you this month. Anyways, had a chance to open that thing up yet?
Old Mar 6, 2007 | 11:35 PM
bindelsf2's Avatar
thanks, and no i havent yet theres still 8" of snow on the ground and the fairings all just got sent out for painting/airbrushing.
Old Mar 7, 2007 | 02:55 PM
328citony's Avatar
Man you guys make me wanna start this today. I just needa find me a 900cc engine. Where should I start looking? bindelsf2, rsp919
