Originally Posted by subyman1440
(Post 1190885)
I heard that the F2 has a specific code name (MV9) on some of the parts. I'm going to see if my F2 engine says that. If so, then I may have found the solution.
F3 motor will run on an F2 harness.Been there,done that.
Aftermarket tensioners are swapable between the two motors.Been there done that too. F3 intake boots are 2mm larger.I've seen F2 carbs mounted on an F3 motor. The back of the cylinder head will have 3 letters on it between #2 and #3 cylinders.MAL.Plus the head will be a wee bit more shiny than the F2 head. |
Did the cdi unit plug straight in?
this website list most bikes and specs for each bike by year and type. If it doesn't give you engine codes ask in the forum... lots of very intelligent guys on this site... probably someone knows the specific engine code to help you... god luck :)
1991 Honda CBR600 F2 Motorcycle Specs |
Originally Posted by partsguy
(Post 1193124)
F2 -f3
Originally Posted by roboto65
(Post 1191019)
The F3 engines have a speed sensor by the starter for the electronic speedo but guess on an F2 it could be plugged.
No.
| All times are GMT -5. The time now is 05:41 AM. |
