-   CBR 600F2 (https://cbrforum.com/forum/cbr-600f2-16/)
-   -   Engine difference? F2/F3 (https://cbrforum.com/forum/cbr-600f2-16/engine-difference-f2-f3-141795/)
subyman1440 Sep 9, 2012 01:53 PM
I'm getting a deal on a CBR engine for $100! The question is, the seller doesn't know if the engine is an F2 engine, he saids it might be off an F3. Is there any way to tell? Thanks in advance
JankCibberf2 Sep 9, 2012 03:00 PM
The wiring harness is needed if its an f3 besides that not really anything
partsguy Sep 9, 2012 03:06 PM
IIRC there are two small water lines coming from the water pump to the back of the cyl head on an F3 and just one on F2's.
A Honda dealer should be able to tell from the eng #,if he knows his job.I know the intake boots were changed but they may be the same size/same place.
coalminer frank Sep 9, 2012 06:12 PM
The cam chain tensioner is different looking .
partsguy Sep 9, 2012 06:25 PM
Yep,different tensioners.Would expect it to be on the new motor.
coalminer frank Sep 9, 2012 11:20 PM
I'd like to have a spare motor, not to thread jack, excuse me.
subyman1440 Sep 11, 2012 11:01 AM
I heard that the F2 has a specific code name (MV9) on some of the parts. I'm going to see if my F2 engine says that. If so, then I may have found the solution.
roboto65 Sep 11, 2012 07:32 PM
The F3 engines have a speed sensor by the starter for the electronic speedo but guess on an F2 it could be plugged.
partsguy Sep 11, 2012 07:57 PM
Yes and MAL is F3,can't recall if they actually put it on the cases or head anywhere though.
coalminer frank Sep 11, 2012 08:05 PM
I believe the cam timing and/or ignition timing is different.
