electrical problem
Old Aug 22, 2006 | 09:24 PM
bindelsf2's Avatar
Default electrical problem
so here it is for your diagnosis:
yesterday i went to go to work and the bike turned over like a low battery- kind of slow and weak
went to come home and it was ok
today went to go to work and same thing sluggish and weak start like a dying batt.
tonight- went to start it and nothing.... no lights or anything..
i have checked all of the fuses including the 30amp main, i hooked it up to a batt charger and got lights and a click's from the starter relay but its not turning over???
any help is appreciated!!
i say bad starter relay?????
Old Aug 22, 2006 | 09:27 PM
bindelsf2's Avatar
Default RE: electrical problem
i am going out now to hook the POS of the batt charger to the POS of the starter motor to see if it turns over too...
Old Aug 22, 2006 | 09:37 PM
bindelsf2's Avatar
so i hooked the pos up to the starter and all that it did was hum and vibrate but didnt turn over...?????????
Old Aug 22, 2006 | 09:39 PM
mikequinn's Avatar
try shorting across the Relay / solenoid, see if it turns over , if it does there's your problem
Old Aug 22, 2006 | 09:43 PM
TennesseeCBRF2's Avatar
Fully charge your battery and test the voltage with a meter. The reading should be at least 12.8V. If it's less than that the batt needs to be replaced.
Old Aug 22, 2006 | 09:47 PM
racer212's Avatar
A battery charge usually will not supply enough power for a conclusive start test. You gotta have a good battery.
And given the tendency for reg/recs to go bad on these, make sure you have a good battery, then check the voltage level of the battery with the bike running. If it's low at idle and way high with rpm then your reg/rec is bad. This is always the first thing I look at with electrical trouble of any kind on old Hondas.
Old Aug 22, 2006 | 09:59 PM
bindelsf2's Avatar
sweet thanks guys i am going to look at all that and get back to you!
Old Aug 22, 2006 | 10:08 PM
bindelsf2's Avatar
batt was 12.70V and i arched the starter relay and all the starter did was hum?? bad starter???
Old Aug 22, 2006 | 10:14 PM
bindelsf2's Avatar
but still no dashlights or anything from the starter relay untill i put the battery charger on it ----then i get lights and the starter relay to go zzzztzzztztztztz..
Old Aug 23, 2006 | 01:31 AM
bindelsf2's Avatar
ok so i have done some more troubleshooting.
took the starter out and hooked it up directly to a batt charger--and it spun
hooked the batt charger up to the batt terminals and read 9V into the starter relay and nothing out.
please offer up input so that i can race on Sat!!!
