Electrical Issue...I'm Stumped
Hi everyone,
New to these forums but not new to motorcycles- hope you guys can help! I purchased a '93 F2 a few months back as a bike for the girlfriend. It had been down but was running fine, so I cleaned the carbs, put a few fairings on, replaced, the clip-ons, etc. to get it ride-able for her as a beginner bike. We were about a mile away and I was having her practice in a parking lot with it a little bit (her MSF class is this week). Towards the end, I wanted her to go through the startup checks so I hit the killswitch, turned off the ignition, half choked it, put it in gear, kickstand down, etc. She went through all the checks just fine and when she turned the key, no dash lights or anything. Let the bad boyfriend jokes commence. I tried troubleshooting there but got nothing out of it. We were about a mile from home so I started pushing the bike back. On the way back, three times the dash lights and headlight came back on (I had left the key on and killswitch in run) but once I hit the starter, everything disappeared again. So here are the state of the electronics of the bike:
I have not been able to get the dash lights/headlight to come back on since it has been parked in the garage. Any ideas? Usually my first thought is r/r, fuses, or connection somewhere in the killswitch but it all tests out fine. Appreciate everyone's help! |
Sounds like a loose battery cable.
Check the base of the ignition switch for poor connection.
Best of luck |
checked both to no avail. base of ignition switch looks clean and tidy and battery cable was down tight when putting back together to test.
Try a set of jump leads. I know you have stated it's a new battery.
Let it run and wiggle every connection and part of harness you can get to until the problem happens again.
Originally Posted by 74demon
(Post 1305247)
More importantly, the girlfriend is loving the MSF class and the bike is ready for when she's done. She's a happy camper and so am I. :icon_hug::icon_beerchug: Thanks everyone for the responses! |
So the saga continues...
I had the cbr out a few times no problems. I went to start it the other day and it is out of gas. There was a leak with the petcock, which I repaired and put the tank back on the bike. I go to start it and get the same thing as before where I turn the key and there is no power or anything, which makes no sense to me because all I did was pull the tank off (with the rear fairings and seat) and did not touch anything electrical. I did find out that if I pull the battery leads off and put them back on, it goes away and I can attempt to turn it over as normal. However, this time it struggled once or twice and now won't turn over. It gets power 3 out of 4 times (fourth time I have to pull the leads off and put back on). This last series of trying to start it, I got a few sparks near the battery and the lead on the battery tender connection started melting and smoking. It has refused to turn over since then. I've been up and down it again and struggling to figure out what is going on. Battery after all my testing and hitting the starter button the last two days is still pulling 12.6v. Fuses are still good. I'm thinking maybe the starter is shot? Thanks again for the help. |
Another detail to add to the equation:
I pulled the starter relay just to make sure the fuse wasn't blown or anything. When I pulled the fuse out, it was a 40a. I believe it is supposed to be a 30a for that main fuse under the seat? The best part about someone else's projects. :icon_slap2: Could it be as simple as the starter relay or starter motor are burnt out from too much amperage? I've looked around, but does anyone have a step by step guide for testing one or both with a multimeter? Thanks! |
