Connected gas lines from gas tank, now wont start..
Old 03-30-2014, 10:15 PM
Default Connected gas lines from gas tank, now wont start..
Hey,
So i took off my gas tank to check out the carbs, and i put it back on and and connected everything, and it doesnt start, and yes i put the gas petcock to on...
does anyone know where i can find a diagram or photo of what it should look like? i cant find anything
any help would be AWESOME. Good weather soon, NEED TO RIDE lol
THANKS,
Tom
Old 03-31-2014, 12:45 AM
for example, i connected the hose to the petcock, and the vacuum hose next to it. and i tried starting her up and it was a no go...ill post pics up tomorrow
Old 03-31-2014, 05:08 AM
PossibleOne's Avatar
Welcome Crew Technician
Sometimes it just takes a little bit for the fuel to get into the carbs. How long did you wait? Here is a fiche of how it should go....
1992 Honda CBR600F2 A FUEL TANK | Babbitts Honda Parts House
-Poss
Old 03-31-2014, 07:17 AM
vent lines at the bottom kinked?
kill switch? lol
Old 03-31-2014, 07:57 AM
ignition on ? lol
Old 03-31-2014, 09:02 AM
Mattson's Avatar
Vacuum leak? Pop the vacuum line from the cyl 1, then pull the fuel line from the petcock, attach a tube to it so you won't spill gas all over the engine and suck on the vacuum line, you should be getting a stream of fuel out.
But yea sometimes the answer is the simplest, my killswitch can be a little...fiddly, I can get it so that it LOOKS like it's on but it actually is off, which is why I never use it. Make sure you're getting spark.
Old 03-31-2014, 09:22 AM
Migge's Avatar
+1 on Mattson. I too have desperately searched for a mechanical error when in reality it is a glitchy killswitch. Because of that, never use it unless I have to.
Old 03-31-2014, 12:31 PM
thanks for the tips guys, would of never thought of mattesons idea, what i was thinking that fuel wasnt getting in either and there was just an air bubble in the system. thanks!!!! i will try it out righttttt now
Old 03-31-2014, 06:59 PM
got everything to work!!!!! thanks alot! i just had to wait a little bit apparently. my idle is crazy though now. it idles at 1500 for about 10 seconds, then it skyrockets to 3500 to 4000. it was after i put the idle screw in(which was a b... to put in) most definitley will need to rethread it, or unfortunatley get a new carb... i had to force screw it in with plyers. The weirdest part is when it gets to 3500 rpms and i put the choke on it the bike just dies...so im thinking that the choke may be on the whole time..any ideas?? just got the bike in, no time to check it out at the moment. just looking for any ideas ppl have..
thanks!!!
Old 04-01-2014, 12:05 AM
Registered Users
On my 94 if the bike is warm at all and I choke it,it instantly dies.Also with choke on as the bike warms
up the rpms will also increase.That's when you turn choke goes all the way off.
Quick Reply: Connected gas lines from gas tank, now wont start..
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
