Clutch, drain oil or no?
RE: Clutch, drain oil or no?
I've only pulled a clutch twice, but it seems to me that if you overfilled the oil (by a lot) and pop the clutch cover off, you're going to have a big mess if you don't drain the oil.
Also, you might want to do some degreasing in the clutch area? (I dunno, maybe not) If that's the case, you would have to drain the oil.
Some bikes lean over enough that the oil sits low enough in the pan that you dont have to drain it to remove the crank cover.
It's a hassle to find something clean to store the oil in, and to have to clean the funnel / catch pan afterwards.
Shaving your face every morning isn't hard either, just annoying and time consuming!
