Choke walking on me
Old 09-01-2009, 03:23 PM
SeanPMN's Avatar
WooooooooooooooooW all I can say. I know my bike is cheap looking but COME ON!?!?!? lol
Old 01-11-2010, 08:55 AM
SeanPMN's Avatar
Is there a vacuum line that connects the choke to the engine? Anytime I do close to wide open throttle, I can see the choke move to stave the engine, then when I stop... if I haven't moved it it stalls. Does that help anyone that can help me?
Old 01-12-2010, 11:15 AM
JimmyHoffa's Avatar
Originally Posted by johnnyx
He means he starts with the choke off, and it slowly turns itself on, thus throwing too much air in the mix and killing the bike.
Someone is confused about what a choke does... Just playin'.
SeanPMN, I think you might just have a broken, bent, or stuck choke return spring/plungers. The mechanism is incredibly simple. No vacuum business, no electricity. As mentioned above, there's just a cable, some springs, and a plunger in each carb to meter the fuel. That's it. When you get the airbox off like johnnyx said, it should be pretty obvious. If necessary, post pics and I'll tell you what's broken. I have taken it completely apart about 3 times, and have had the carbs off as an assembly a few more times than that. I know what to look for. It could also just be that the slider pins that guide the large choke silder have goo all over them, and the normal vibration of the engine is such that it just kinda ratchets itslef open. Could just be a WD-40 fix...
Old 01-12-2010, 12:23 PM
bambam's Avatar
i get what a choke does JJ, what i dont get is that the choke lever rises. on my 93 900 RR the choke wont stay on , it slowly starts to close on its own, ive never seen the opposite...i have seen the plungers in rough shape, however the slide actually worked but a little stiffer...i agree tho, it wont take 20 min. to get thwe tank and airbox off for inspection, all the jawjackin in the world wont replace hands on ...
Old 01-12-2010, 07:11 PM
JimmyHoffa's Avatar
No bambam, you're clean. It was just mentioned earlier that a choke throws too much air in the mix, when it's just the opposite. It throws too much fuel in the mix. Engines require a richer mixture to start cold, and a choke provides this.
montana.matt
The Hurricane Saloon
10-19-2012 06:29 PM
jasonb
03-06-2011 12:59 AM
Ratt
07-28-2009 12:37 AM
MarkR
03-26-2006 02:33 AM
Quick Reply: Choke walking on me
