Charging issue.
Charging issue.
Hey guys looking for any advice here. Last summer I cooked my RR. Replaced it and all seemed well for a few quick rides but then the battery wouldn't charge. The stator seemed okay. I had good voltage but I replaced it anyway just in case and got a new battery as the old one ended up being cooked which I thought was the issue. Well nice weather is here and it's doing the same thing. Again I have good stator voltage and I can even see it fluctuate at the battery terminals when I rev it. I have not done another RR check but it seems to be fine. When it went last year it melted a couple fuses but I replaced them. I also looked at the wiring harness in all the suspect spots and I didn't see any melting at all. If anyone has any ideas what I should look at next I'd appreciate it. I also have an aftermarket HID but I don't suspect that's the issue.
Batteries and reg/rec are the main problems. Did you replace the RR with an OEM honda or an aftermarket one?
The old stator had a weak output so it was time to be changed. Barely was making 12 volts. The RR is aftermarket. The Honda one is discontinued. I'll have to find the test procedure again check the new one. If not I might buy a new wiring harness. It's not that expensive and mine has been hacked in a few places. Anyone have any other ideas?
I've personally fixed probably a dozen F2 with charging problems. I've always used Honda OEM RR and they reliable and last. Now I will say that the original Honda RR sucked (epoxy filled ones), but Honda updated the part to one that has fins a couple years ago and they just plain work great. It's not worth saving a couple buck on an aftermarket one. Or getting stranded somewhere. Anyway, the new part number is 31600-MV4-010. I don't think they've been discontinued. I found a couple places showing them in stock.
https://cbrforum.com/forum/f2-tech-93/charging-system-problem-help-please-152933
So the old stator was bad which may or may not have fried the new RR but either way I replaced the RR after I confirmed the the old stator was bad with a nice new Honda one (thanks Phil) and she seems to be running like a champ once again. I wonder how many more years I'm going to get out of this old girl. One thing I do know is I'll keep riding her until she explodes.
Thanks again for the tips guys.
