Cct
Old 06-10-2009, 05:54 PM
CaliKush's Avatar
Default Cct
94 f2
so i was riding along whistling to some random tune.. then i notice my bike starts to sound... like a cruiser sorta.. it has a deeep deep mumble to it but only in the low rpms along with a rattle below the gas tank.... if i roll the throttle then it sounds like how its suupposed to! so i roll into a neighborhood to cruise around to see if it would keep makin that noise. it starts to bother me so i turn off the bike for 5 min then turn it back on.. it hesitates to turn on for the first few times.. then it finally turns on but still has that rattle and the deep mumble.. so im guessing its the CCT. and it also runs like shyt in the low rpms.. are these symtoms of a CCT needing to be replaced?
Old 06-10-2009, 06:20 PM
Sand.Man's Avatar
Is it your clutch rumbling?
Old 06-10-2009, 09:44 PM
CaliKush's Avatar
it sounds like its coming from above the clutch...
Old 06-10-2009, 09:58 PM
tundrafiend01's Avatar
Sounds like bad gas / the carbs need cleaning to me.
How long has the bike been sitting?
Old 06-11-2009, 03:28 PM
CaliKush's Avatar
i actually bought the bike not running because the carbs were clogged. so i cleaned them out myself.. which is not the proper way..
Old 06-12-2009, 01:16 AM
CaliKush's Avatar
so i noticed that when i switch it to reserve tank.. it doesnt have the low mumbling exhaust noise anymore..
Old 06-12-2009, 09:10 AM
Possibly a clogged petcock Or you're low on gas and need to fill the tank? If it's the petcock, there's really no use trying to rebuild the one you've got. Keep an eye on ebay and see if you can't get an F3 petcock in decent working condition.
Old 06-13-2009, 03:03 PM
CaliKush's Avatar
is it bad to run on reserve all the time?
Old 06-13-2009, 03:16 PM
Sand.Man's Avatar
It will not harm anything, but if you run out of gas you are screwed...
Old 06-14-2009, 06:31 PM
77vetteguy's Avatar
what happens if you don't fix the cct?
