-   CBR 600F2 (https://cbrforum.com/forum/cbr-600f2-16/)
-   -   CBR600F2 won't light up (https://cbrforum.com/forum/cbr-600f2-16/cbr600f2-wont-light-up-165212/)
Chrīs Nov 30, 2025 04:03 PM
Hello, I have a 1994 Honda CBR600F2 that I had bought not long ago. It worked up until halfway home where it stalled out and died. I found out it had an issue with its regulator and replaced that, but whereas before it lit up and drove around, recently it just doesn't turn on whatsoever. I've tried hooking up my old regulator to see if it was something with the new one I had got and had no luck. Since then I've replaced all fuses, the starter solenoid and I hooked up a separate ignition switch and none of these helped. I kind of suspect the problem lies either in the ECU or the actual harness itself but I'd love to hear any advice! I've also checked the voltage of the battery and load tested it and it's a-ok. Appreciate any help guys!
