CBR Temperature gauge
It is a water temp gauge. Your aftermarket gauge might or might not work with the original temp sensor depending on the ohm range of your gauge, my google-fu isn't good enough to speed-check what the ohm range for the original sensor is, but if it doesn't read correctly you can always put an another temp sensor into one of the coolant hoses with one of these:
Do not swap the original temp sensor to match the gauge as that controls the fan.
Armstrong
06-08-2006 08:31 PM
