CBR sounds like diesel truck engine
I still think you need to replace the cct with a manual one. Or the cam chain itself is just plain streched & needs replaced. Just because you have taken it apart & cleaned it, doesn't meen its good. The radiator fan not working is not going to cause the cam chain to rattle. Fix the cct, then address the radiator fan issue.
I will definitely invest in a manual cct. From what it looks right now, it seems like best option. However, I have a question and that is, how do I adjust it?? Like I'm sure I'll over tighten it and snap my cam chain or increase wear. Is there a way to know when the manual cct has the recommended tension settings?
