CBR RR WHEEL AND TIRE
RE: CBR RR WHEEL AND TIRE
you could probably make the front wheel work....the axle size is the same....might need to make adapter brackets for the brake calipers as I think the rotors are larger. Also, no speedo drive.
I bought a rearF3 wheeloff eBay that turned outto bea 900rr wheel...the seller let me keep it so I thought I'd look into fitting it. NOPE....without major rework to the cush drive, spacers and brake mount, there is no way thats going to fit....well, it would fit, but it would not be in line with the front wheel after you got the sprockets in line. The 900RR and newer 5.5" wheels on the 600's share some interchangability...so I suspect the F4/i wheel would be the same issue.
