Carb sync
Does anyone know if there is a thread bout carb syncing using gauges or can someone explain how this works, i have a set of gauges and need to sync the carbs. Thanks
look for a video on youtube for f2/f3 carb sync. its a pretty straight forward process and having gauges, vs manometer, makes it 20x's easier. Just remember that you wont be able to adjust one of the carbs, most likely #3, and you just use that one as a reference to adjust the rest to.
Sjona2011
Thanks for the tip on the YouTube "carb sync using gauges" video. Unfortunately, 10 minutes of search has not been productive. Think you could help me find it? Wife is an RN and will be bringing me some IV tubing that I plan to use to tie all the carbs together to my vacuum gauge. The tubing includes "roller" type shut-offs and I think the main challenge (connection-wise anyway) will be manifolding all the plumbing to the gauge. Looking forward to your assistance! Thanks in advance. Benj68, did you find the video? |
talks a lot of rubbish but not bad or that one |
Balance videos
Thanks!
