Carb question
Old Jul 24, 2007 | 08:22 PM
hurayta's Avatar
Default Carb question
I have a 93 F2 and when I'm rolling on the power the bike starts to stumble around 4500 rpm on up to about 5500 rpm. Also, when I let off the throttle and the rpms are up, i get a little bit of a back fire. I bought the bike used and other than the mention problems it runs great. It does have a Yoshi exhaust system on it. Does it sound like the carbs need rejetting, or could it be something else?
Old Jul 24, 2007 | 08:43 PM
MikeInCtown's Avatar
Default RE: Carb question
Everything I've read and from what I've been told about my bike, you need the carbs cleaned, then checked to make sure they have the correct jets.
Old Jul 24, 2007 | 08:57 PM
littlecbr's Avatar
I agree with Mike's comments. Sounds like the jetting isn't correct to cover-up the stumble around 5k RPM. I have a '92 F2 with a Two Bros pipe. Stage 1 jet kit really helped in the midrange. I have too been noticing some backfiring when coming off the throttle. I believe that is a characteristic of it being too lean.?? I have also noticed my bike getting much louder over the years. I think it is time to get the pipe repacked.
First thing is to take the carbs apart and look at the needle jets and main jets. If you need it, I can look through my notes for my stage 1 kit which will tell the main jet sizes.
Good luck.
[IMG]local://upfiles/7469/B86786D51AE641F380D8DA04B916258D.jpg[/IMG]
Old Jul 24, 2007 | 09:49 PM
hurayta's Avatar
Thanks for the info.
LitlleCBR, that would be great. I can check what your stage 1 kit had against what my jets are.
The stumble seams to happen after I have been riding for around 50 miles or so. I recently changed the air filter to a K&N, simple because I can clean it versus buying a new one, and havent had the time to go for a long enough ride to see if it helped with the stumble or not, but I did notice a little bit less of a backfire when coming offf the throttle.
Old Jul 24, 2007 | 11:42 PM
BlkF2's Avatar
back firing would be a to rich mixture usually. the un burnt gasses in the exhaust will ignite..
Old Jul 25, 2007 | 10:27 AM
littlecbr's Avatar
Here is a link to the Dynojet kits. Scroll down to the F2 model and you can view a .PDF on the kit. I will check which mains I have in mine.
http://www.dynojet.com/jetkits/hondajets.shtml
Old Jul 25, 2007 | 05:52 PM
ORIGINAL: BlkF2
I agree with the backfire, but I think what he may be having is a popping sound at decelleration. IIRC, that indicates a lean condition.
Old Jul 28, 2007 | 06:04 PM
littlecbr's Avatar
I have 124 mains in mine. Needle position is in #1. The kit came 118, 122 and 126 mains with it. A guy at a localshop did a lot of work with F2's (with a pipe) and suggested a setup using 124 mains. We used that and put it on the dyno and looked good. I have been happy with it.
odano1988
Sep 15, 2015 07:26 AM
sempul
Sep 11, 2009 09:38 PM
bosterfeld
Jul 23, 2009 06:25 PM
cbrstuntin05
Oct 9, 2008 07:36 PM
novaf3
Apr 8, 2008 01:25 AM
