cant get carbs off. any suggestions?
Old Apr 7, 2014 | 01:54 PM
tomekzski's Avatar
Default cant get carbs off. any suggestions?
So i got to the carbs. Unscrews the screws at the bottom. I tug pull push yell and the thinf wont come off? Any suggestions? Thanks
Old Apr 7, 2014 | 02:00 PM
Mattson's Avatar
Carefully pry them out with a tire iron, crowbar, piece of board etc, if the rubber boots have hardened they can be mighty stuck. Just be careful not to bend anything so look carefully where to put the lever.
Old Apr 7, 2014 | 02:02 PM
tomekzski's Avatar
Weird thing is is that i got them off before easily and noe they will not budge...i put wd40 on the metal piece they slide onto do that they get back on easier and now its just not getting off at all. And itd difficult to to pry them with something. Nothing really to put leverage on but thanks i will keep trying
Old Apr 7, 2014 | 02:11 PM
tomekzski's Avatar
Finally got them off! I used the handle of a shovel against the frame just in case anyone in the future has the same problem. Thank you mattson
Old Apr 7, 2014 | 02:13 PM
Mattson's Avatar
Just to be sure I checked from the manufacturer's site and they claim wd-40 should not have effect on rubber but I have had some similar experiences where wd has "glued" rubber and metal together over time.
Old Apr 7, 2014 | 02:29 PM
JamieDenny's Avatar
me too but just make sure you clean it off now the carbs are off.
Old Apr 7, 2014 | 03:32 PM
tomekzski's Avatar
yea thats what i did. i was wondering that the wd40 mightve gotten it stuck under heat, but who knows. as long as i know im idling good im happy
RJDiesal
May 3, 2008 10:37 PM
medders22
Apr 1, 2008 03:54 PM
ffry6326
Apr 19, 2007 01:04 AM
JSTATL
Jul 3, 2006 09:10 PM
