cam chain and cam chain tensioner
Old Jan 18, 2009 | 10:02 PM
jalate compa's Avatar
Default cam chain and cam chain tensioner
ok there was a horrible sound inside my f2 head engine , it came sudenly so i replace the cam chain tensioner
for a brand new one that i bought it from a honda dealer.
(imerse the chain tensioner in clean oil before install it)
so it took me like 15 minutes to replace it and then i rode my bike for 3 or 5 days, and the horrible sound apeard again
but it was so intense this time. so i bought a brand new timing chain from the honda dealer and i replace it for the old one
and the noise past away.
I spent more time getting all the bike parts apart, than installing the new chain, you dont have to remove the head engine,
you only have to remove the cam shaft cover ,the camshaft trees and the small cover where you set the timing , the one by your
right leg. so radiator,and fairing,and front light and all of that, you have to remove it.
Inside, where the cam chain goes, i mean when you remove the cover by your right leg to get the chain out
you need to remove a plastic brown gide(chain gide) to take out the old chain and set the new one(chain)
so is "very highly recomended to use a tork meter tool and set the torcks from the service manual"
questions are welcome in my e mail or via messenger happy rides
Old Jan 18, 2009 | 11:03 PM
f3BikeR's Avatar
Default RE: Horrible engine sound¡¡¡fixed
Some punctuation might make your post more presentable and credible...
But thanks for the heads up about the cam chain-
Old Jan 19, 2009 | 11:52 AM
99LS1's Avatar
Yeah no offense, but it was very hard to read that.
Umm but yeah.... How is someone going to know that the noise on their bike is the same noise you had? You didn't explain the noise, or when it happen for example cold start, warm. ect.
Old Jan 20, 2009 | 08:32 PM
99LS1's Avatar
That is much better! lol, not trying to get on your case but it was hard to read. That is so good info!
Old Jan 23, 2009 | 07:26 PM
sorry too much tequila that night
Old Feb 14, 2009 | 05:04 PM
Barkstrom_JB's Avatar
Talking thanks
you just made my life a whole lot easier. Cam chain on my F3 went too. Swapped it out and that did the trick. New chain direct from Honda plus an APE manual CCT should hold up quite nicely.
Old Aug 11, 2009 | 12:24 PM
jk72180's Avatar
does the chain come together or do i have to have the tool to close the link. ordering the chain and need to know if i need to locate a tool qhile i wait for it. thanks.
Old Aug 12, 2009 | 07:04 PM
Sand.Man's Avatar
It should be an endless chain
Old Sep 20, 2009 | 08:40 PM
tcaffee600f4i's Avatar
Go to this web site and and there is a easy fix that Uncle Jeff has come up with.Here it is
CBRWorld.net - OEM CCT MODIFICATION PIC'S he seem to know what he is talking about he has wrote alot on the bb noise check it out and let me know what you think I am going to try it.
Old Sep 21, 2009 | 12:23 PM
duececivic's Avatar
how long did it take for u to change the timing chain and tensioner
