Blinker Issues
Hi,
Just bought a nice 93 CBR 600 F2 which is my 1st road bike. Anyway today I lost my left front blinker....the running light works in it but when I turn on left front only it blinks and clicks quickly. All other light work properly....left front blinker only problem. It was working fine when I bought it. I replaced the bulb and am having the same issue. Is there a way to test for the pulse voltage with a meter....I'm thinking it may be the lamp being that it is a little loose in the fairing and may have been bouncing around a bit. /shrug Ive tried jiggling and tugging and I get nothing. Wires at the back of the lamp look solid. any clues? thanks! |
*bump* Help Please!
Did you try tracing the wire back all the way to its source? maybe there is a short somewhere. just my opinion
The Orange wire is the postive lead from the relay. Using a volt meter, trace that wire starting from the plug into the bulb and make sure you have an alternating voltage. If you don't find it, follow the wire back until you do. Once you do, again work forward until you find where the connection has been interrupted and there's your problem!
