Bike dying at half throttle. Please help
hi i have a 92 cbr 600. nightmare lately
i bought that bike last month. ran flawlessly for the first two weeks. then it started idling like crap and stalling when getting anywhere passed cool temperature. i tried everything including Sea-foam carb cleaner, that i added to my fuel tank. that did not help. i pulled every single plug, checked the air filter, check every fuel line, took the fuel line of and tested the petcock, checked every vaccum hose that i could find (there are a lot of them) and still nothing. i also checked the fuel pump (which might be my problem what do you guys think?) i gently unscrewed the back of the petcock and the fuel pump seperated a little bit and i screwed it right back together. (i didnt start the bike since i put the Sea-foam in). so now i start the bike and it still idles like ****, and now i cant go passed half throttle. (white in neutral of course) i can twist the throttle all i want and its smooth. but as soon as i get to half throttle the bike practically shuts off!! after 6 hours i tested the coils and wires wth a voltmeter and found out that my #4 wire had barely any resistance. so i replaced that and now it starts and idles great. but i still cant go passed half throttle!! its so friggin weird! if i slowly build on the throttle (while in neutral) the rmps are smooth and steady, as soon as i get to 5800 rpm (about half throttle) the bike engine just completely dies and will just shut off if i hold it there.
its like a do or die. it doesnt slowly run like crap the higher rpms i get. its great. perfect. and at half throttle just immediately shuts off. what do you guys think?? its kililng me
![Frown](https://cbrforum.com/forum/images/smilies/frown.gif)
edit: oh and ive checked the drain bolts on all 4 carbs and they were all full with fuel and poured out. so im getting plenty of gas from the tank
Your bike has a fuel pump? My '91 doesn't. Mine's gravity fed. Sounds like the dreaded dirty carbs!! You'll need to take them off and apart and go through them. I had to do it to mine to make it run. There's a Hell of a carb cleaning tutorial in the tech. section. I highly recommend it. I'm going to sync. mine this weekend so mine should clean up 'tween idle and 2K. Good luck!
You've mentioned the fuel pump a couple of times, but the F2 (in stock form anyway) does not have a fuel pump or fuel filter, other than the screen at the bottom of the tank, where the petcock connects...I know it seems like a dumb question, but, are you sure this as an F2 and not an F3?
Well its a 1992 600. Almost positive its an f2.... and i am positive that this diaphram with the rubber disks and the spring in the back of my petcock is a fuel pump.. and there is a vaccum hose that goes to it to pressurize the tank. And i dont think this bike has a fuel filter? Cant find it anywhere. But thats not the problem because when the petcocks off fuel flows 100%. And its not gravity because when i take off the tank and turn the petcock to on or reserve no fuel comes out but when i pressurize the tank it fllowss out. And idk how the carbs could get clogged in a matter of 10 minutes. Possible i guess tho. Maybe the SeaFoam carb cleaner moved sone dirt in the carb into a jet or orphus in the carb.
![Icon Frown](https://cbrforum.com/forum/images/smilies/icon_frown.gif)
