Airtech undertail
RE: Airtech undertail
Sorry guys, I dont have any pics of the undertail on the bike. All I have are pics of the undertail and a couple of pics showing the after results of trimming trunk tray down.
[IMG]local://upfiles/14923/9D33752933784587AC152F3A388DE263.jpg[/IMG]
[IMG]local://upfiles/14923/281A44F3E51F4866B12D5707801687E8.jpg[/IMG]
does any bidy know if i need the stock plastics for the undertail to work?....i currently have the cheetah race plastics that i have converted to street legal....with lots of mods......lookin to clean up the undertail a bit a want to know if they fit to the stock plastics....thank you!!!
trevor
trevor
NKX, it is made of fiberglass. The piece has a white gelcoat on it and is a pretty heavy duty piece. The only issue that I had was the amount of space inside the area where I mounted my turn signals and the license plate bolts. I had to make sure the the turn signal stems and the license bolts didnt fall inline with each other. I also use a set of white LED accent lights that I picked up at Auto Zone for my license plate lights. If you are able to zoom in on the picture of the back of the bike you will be able to see them just above the plate.
Mine is attached with just two small bolts. One thru the undertail and into the compartment for the tools, the other screw goes thru the undertail and up into the plastic trunk area. I have a small spacer between the undertail and the trunk piece. With this mounting configuration I can grab the undertail on either sid near the back and lift the bike to move the back of the bike over.
