adjust carb.
I HAVE A 93 CBR 600 AND I TURN SOME SCREWS ON MY CARB. MY ENGINE IS RUNNING AT HIGH RPM. I TURN THE IDILE SCREW BUT THE ENGINE ONLY COME DOWN A LITTLE. I ALSO TURNED ONTWO SCREWS ON THE CARB ALSO. I THINK I HAVE REALLY SCREWED UP BAD. WHAT DO I NEED TO DO TO GET THE CARB RESET AGAIN?
RE: adjust carb.
is the choke on? what screws did you turn? pictures?
RE: adjust carb.
probably didnt turn the idle screw down enough..I would start the bike and just keep turning it all the way down..till the rpm's start to drop
RE: adjust carb.
there are a screw on the actual carb undernet the air box.
RE: adjust carb.
i turn that screw until it came out.
RE: adjust carb.
theres a bunch of screws lol if i seen where it goes i would be able to help you.
RE: adjust carb.
well why cant you just take that screw and put it back in?haha..whats the actualy problem.?you dont remember where it goes?.Forgot how to use a screwdriver?..
RE: adjust carb.
ORIGINAL: 94cbr600kid Forgot how to use a screwdriver?.. [sm=owned.gif] lol |
RE: adjust carb.
sorry but im not fully understanding his question i mean yea there are screws under the carbs.But if he thinks thats the problem..why cant he just put it back in? ya know.haha
[sm=ttiwwp.gif] |
RE: adjust carb.
The screws you prolly turned and to remove the gas from the bowls, which prolly didnt leak cause they are all gumed up inside.. put it back together and turn the idle all the way down as far as you can....make sure the choke is not stuck on at all and make sure your throttle is not stuck too..
