94 f2 will not start but it will bumb start why?
Guest
Posts: n/a
Hey Guys, i just bought my f2 yesterday an rode it home.about 45 miles with no problems, she bogs out once but i regain it an keep going. im 1 exit away from home an the bike bogs out an dies on the highway like wtf. today i tore it down, cleaned the carbs 1# was sticking 2#3#4# had hella dirt sprayed them all alot, she ran fine turn it off turn it on about 5 times no problems, i drove it down my driveway with no problems. i go back inside hang out for a few come out try to start an it doesnt start but i bumped it an it ran fine temp gauge was a quarter way up not even half all night long no problems but if she shuts off i have to bumb it o yea im a noob PLEASE HELP i feel like i paid 900 bucks for something that doesnt work
Is the bike turning over quickly, or does the starter sound like it is struggling? Sounds like the bike plugged up on the way home due to crud in the tank. When it died on the freeway did you push it home or did you wait and restart it?
Like squale's post, the r/r could be overheating and killing your spark or not charging the battery properly which affects spark too.
A little more info would help.
Guest
Posts: n/a
Its a struggle with the start button..lights flickr battery dies then I begin to bump it I don't know what to do guys
I pused it a mile brought it down a on ramp lol an put it in the woods for a hour came back for it an still wouldn't start till I found a small hill gut she had major prpblems that whole nite..an now everything I turn the choke off she shuts down or choke off an 1st gear
I put new plugs in yesterday Im going to see how that effects it an if it doesn't ill buy a new batt an rec but what type of reg rec do I get it its my first bike I'm lost
Clearly you've got electrical issues, but what those are, you'll only know when you start testing things.
Firstly, do a simple inspection of the plug for the R/R - it is a common issue for the OEM R/Rs to overheat and fail, and one evidence of this is burnt wiring at that plug, often accompanied by the plug's plastic even being somewhat melted.
There's further tests you can do, to check the status of the R/R and the stator - you'll find these in the manual.
Secondly, it seems that your battery has issues holding a charge, and though it might be that a bad R/R has fried your battery with over-voltage, or that your stator is not supplying a sufficient charge, it might also simply be a bad battery - the best way to check the battery is to have it load-tested, there are many auto parts stores who will do this for free.
JayBoCC2
06-23-2009 10:23 PM
