94 f2 gauge lights
94 f2 gauge lights
well my guage lights on my cbr stopped working the only one that works is the tach. i guess one of my lights in the speedo worked then it all completely went out. how do i change the lights or fix this problem? if so what lights do i need to buy or order. need help please.
the cluster comes out as a unit - it's pretty simple. take the 2 plastic covers off the inside of the fairing (the ones that cover up where the mirrors attach). I think there's only 3 bolts holding the cluster in. It does take a little wiggling to get it out, but it isn't impossible. You might need to remove your speedo cable from the hub drive to have enough slack. while you have the cluster pulled out, make sure the speedo cable is tightly screwed into the cluster as well, as they are prone to loosen up from time to time, and are PITA's to screw back in without removing the cluster again.
The gauge backlights are all on the same circuit, so if any work, then they all should. That same fuse also powers the horn, taillight, and turn signals.
