93 F2 fixer upper
93 F2 fixer upper
Ipicked up this fixer-upper that hasn't been started for years. Looks like someone tried to treat the gas tank but it's still some rust in it. Itried an external fuel tank I made with a plastic bottle. When I hooked it up the gas in the bottle drained itself into the engine (I never got the engne started). I figure the floats were not sealing and the gas was flowing into the crankcase. I yanked the carbs and cleaned it up. Rubbed the float seals with alcohol. Drained and refilled the engine oil. After I got the carbs back on I hooked up the fuel tank with a filter to catch any crud before it got to the carbs. Still no start. If Ihold the throttle wide open the engine sounds like it wants to start but doesn't. Any ideas?
var callCount = ((oBw.agt.match( /gecko/ ) == "gecko"))? 0 : 50;
function rmvScroll( msg )
if ( ++callCount > 10 ) { msg.style.visibility = "visible"; }
if ( callCount msg.clientHeight ) {
msg.style.height = ( msg.scrollHeight + delta ) + "px";
delta = msg.offsetWidth - msg.clientWidth;
delta = ( isNaN( delta )? 1 : delta + 1 );
if ( msg.scrollWidth > msg.clientWidth ) {
msg.style.width = ( msg.scrollWidth + delta ) + "px";
msg.style.overflow = "hidden";
function imgsDone( msg ) // for Firefox, we need to scan for images that haven't set their width yet
var imgList = msg.getElementsByTagName( "IMG" );
var len = ((imgList == null)? 0 : imgList.length);
for ( var i = 0; i
DeleteReplyForwardSpamMove... [/align]
Previous | Next | Back to Messages Save Message Text | Full Headers [/align]
for ( var i = 0; i
RE: 93 F2 fixer upper
Pulled the carbs off again and wiped and wiped and wiped (you get the idea) the float stopper rubber tips with alcohol pads. Put everything back together and the bike started. But...it dies if I don't keepreving it. Even after a good warm up the bike won't really idle. I think if I put on a clean fuel tank and petcock assembly it may run better. Any ideas (as far as the idle is concerned)? I changed the oil and filter (again) since gas got into the crankcase.
It revs kinda ok...seems likethe rpmshang a little then comes down.But yes revs OK. I connected the larger air line that connectsto the bottom of the "upper-right corner of the air filter box. There's some air lines that converge under the "fwd-center" of the air filter box that I can't figure out if it connects into anything, so I just left it alone. I didn't see any other lines that needed tobe connected to the air box assy. I fooled around with the idle ajustment,wish it was that simple.
Can You hold the throttle 1/8th open and manually make the bike idle?If so You still should be able to turn the idle screw in until it holds an idle, might take a couple turns.
If it hangs up that is a sign of running lean, maybe a vacuum leak, try using some W-D40 and spraying around base of carbs. Also make sure the gas tank breather tubes aren't clogged.
did you check to see if the fuel mixture screws are in sinc. it should be 1 1/2 turns out. i was having problem like that when i jetted my bike. it would rev up but would catch at 9,000 and hang then slowly drop.check all the boots are you seeding the carbs all the way? air filter clean and box sealed?
check for pinched fuel line, when building my bike i routed the fuel line wrong to the carbs and pinched it on the frame would run for about 5 minutes then run out of gas and die, i would lift the tak fuel would get to the carbs and do the same thins over gain. take the tank off and look at the line if you see any pinches in it you might be having the same problem.
