-   CBR 600F2 (https://cbrforum.com/forum/cbr-600f2-16/)
-   -   '93 600 Fighter project (https://cbrforum.com/forum/cbr-600f2-16/93-600-fighter-project-110907/)
adrenalnjunky Feb 10, 2011 12:03 PM
looks like a suzuki GS500 swinger is almost perfect with a little frame tweaking - now I gotta figure if the F2 rim will fit that swinger.
edit :you can have your thread back now :-)
knifemaker87 Feb 10, 2011 12:11 PM
well if you need any dimentions off an f2 rear wheel let me know.. i have one rolling around now.
Halfpint Feb 10, 2011 12:43 PM
I noticed on pic your 2 outer head bolts are loose? hmmm..
knifemaker87 Feb 10, 2011 12:48 PM
yep. the head isnt fully installed. head bolts are finger tight. or were.. the head is off completely so i can do the exhaust work.
really good catch though
Halfpint Feb 10, 2011 01:02 PM
Your welcome, that's one awesome project.
knifemaker87 Feb 15, 2011 09:17 AM
7 Attachment(s)
alriiiight.
here we go. I sold the Jetta that had been hanging over my head. so there is no more time or money going into it, and i got some cash for it. So i have about $300 added to my budget which take my budget to... you guessed it.. $300.
So right away i spent it on stuff i have been drooling over.
new forks: 02 gsxr 1000's
http://store03.prostores.com/ricksmo...4095f19a_m.JPG
new sprocket set 15t front 43t back
new chain
New iridium spark plugs.
so i have about $100 left and i will get about $200 from the tax refund money to spend on the bike when i comes through.
I also did some research, and pulled the trigger on a shock. the F2 has a very short shock, and the only new nice shock that i could find in the same length range was the CBR 954. so.. i got one of those for about $20. it is a little shorter than the previous spring giving me a little more room to mount it as well as being able to keep the stock linkage mounts and angles.
I also got the rear wheel hub turned down.
http://i23.photobucket.com/albums/b3...7/IMG_2674.jpg
Kinda pretty, dont you think?
Attachment 50424
While i was figuring out where to put the R/R i found this: What do i do with that? is there a way to repair it?
Attachment 50425
I did get the tail tidyed up and the gap filled.
Attachment 50426
now the tail also rests on this "shelf" and make it a 5-point support for the tail
Attachment 50427
ugly welds.. BE GONE!
Attachment 50428
i relocated my ignition...
Attachment 50429
and now the frame is ready for stripping. i am hoping to paint it on Friday.
Attachment 50430
More to come soon!
thanks
~Chris
DagonRais Feb 15, 2011 10:52 AM
How was relocating the ignition? Did you do a test fit to see if it would get in your way when riding or not? Curious cause I'm debating on doing that mod and can't find much info on it, not that it really seems to complicated it's just always easier to see how someone else accomplished it.
knifemaker87 Feb 15, 2011 10:57 AM
i mocked it up while the engine was in, and didnt see any interference. I just welded two long nuts to the frame to hold it there. it was easy. when you say "get in your way when riding" what do you mean? it is flush with the frame... so i would think not.
DagonRais Feb 15, 2011 04:06 PM
By getting in the way I'm referring to when the key is in the ignition.
Now that ive taken a closer look I feel stupid for asking if it gets in the way lol.
Either way it looks like your making great Progress
knifemaker87 Feb 17, 2011 08:19 AM
6 Attachment(s)
the picture was really close and hard to tell where it was located on the frame. no worries.
okay...
i have gotten a little work done.
I finally got in touch with the Ti welder, and i am going to go meet with him at lunch time today. here is what has to be welded
Attachment 50356
I made a coupler and copper gasket. the collector will be welded to the steel coupler.
Attachment 50357
I was also getting too much flex out of the aluminum rearset risers.. so i made a new set out of stainless. it has a cool texture to boot!
Attachment 50358
I stripped the frame in prep for painting.
Attachment 50359
And got the new shock in the mail. old vs new. a Cbr 600 f4 shock vs a Cbr 954 shock. it fits the stock mounting point and rocker.
Attachment 50360
Mocked up the shock position. I am going to get the brackets welded on this afternoon.
Attachment 50361
So. today should be pretty epic as far as the bike is concerned.
new shocks arrive
Getting header welded
Finishing Swing-arm.
and i should paint the frame tomorrow.
more to come!
thanks so much
~Chris
