-   CBR 600F2 (https://cbrforum.com/forum/cbr-600f2-16/)
-   -   '93 600 Fighter project (https://cbrforum.com/forum/cbr-600f2-16/93-600-fighter-project-110907/)
knifemaker87 Feb 7, 2011 10:22 AM
9 Attachment(s)
okay...
so, by jetta (which is now for sale) has been taking up all my time and money.. however the bike has my interest. Hopefully i will get some tax return money for the project too, and when i sell the jetta i will get the bike money back out if it.
i got the gasket set which was able to complete the 4 sets i already had.
So i got busy putting the carbs back together
This is a SUPER TINY o ring on the needle.
Attachment 50673
then the jets went back in
Attachment 50674
http://i23.photobucket.com/albums/b3...7/IMG_2635.jpg
i used a piece of .005" music wire to make sure all the holes were open, but they were all pretty clean.
Attachment 50675
Then the floats went back in. you don't set the height on these! they haynes manual says "if they are out of spec, replace them" so i was very glad to find them in spec.
http://i23.photobucket.com/albums/b3...7/IMG_2638.jpg
I also replaced the hardware on the carbs to get rid of the stripped out phillips heads.
Attachment 50676
got the diaphragm and needle assembled...
Attachment 50677
and installed. (careful these springs will fly across the garage and roll under the tool cabinet)
Attachment 50678
and got the modified air-box on. ready to go on the bike
Attachment 50679
I also got the needle bearings in the mail then in the swinger
Attachment 50680
some custom oilite bushings...
http://i23.photobucket.com/albums/b3...7/IMG_2646.jpg
and... not to brag.. but i think that is HOT! sorry for the blur.
Attachment 50681
now i cant decide about the shock. i cant really mock anything up either because the stock systems interfere with each other. i am going to go with a progressive linkage system, but i cant decide if i should keep the f2 frame mount, or go with the swing-arm mounting point, though i am leaning towards the swinger so i can upgrade my shock, i just think it is less attractive.
thoughts?
bambam Feb 7, 2011 01:51 PM
since the F2 mono is non remote resivior, it might be cool to switch to one off a newer bike , it looks trick so far man. whatcher plans to relocate the F2's mount?
adrenalnjunky Feb 7, 2011 02:40 PM
the 94 F2 had the remote res. shock that carried thru the F3 generation.
Knife - I dunno what you're planning for front turn signals, but I just saw these on bike-exif and thought they were pretty trick - pretty sure you could machine something trick up along the similar design:
http://www.oberon-performance.com/ac...ndicators.html
http://www.oberon-performance.com/ac...k_Lens_150.jpg
http://bikeexif.exifmedia.netdna-cdn...mmarhead-3.jpg
knifemaker87 Feb 8, 2011 06:31 AM
i have been playing around with several options.. however i will most likely keep the stock shock set-up but upgrade the shock and modify the swinger to work.
that is a great i dea! i will def look into it. thanks guys!
~Chris
knifemaker87 Feb 10, 2011 09:13 AM
3 Attachment(s)
I did get a little work done. Annnnnnd... i finished my taxes so i should be getting a little money for the build!
I got the tabs welded (at least tacked) for the radiator supports
Attachment 50619
Got the new carb boots in the mail and fit it on. Now i can see where to run the wiring.
http://i23.photobucket.com/albums/b3...t87/CBR466.jpg
I made stainless bushings... they work much better
Attachment 50620
and now... how do i remove these studs?
Attachment 50621
thanks for reading!
adrenalnjunky Feb 10, 2011 09:46 AM
http://i23.photobucket.com/albums/b3...t87/CBR469.jpg
thanks for reading!
I just pulled up the service manual for a 96-98 900rr and looked at the drivehub info there. The manual shows the back side of the drivehub to be hollow where those studs are. Are they just pressed in like wheel studs are in a car's brake rotor or drum?
I found an image of what I'm talking about - but it appears that the studs are inserted into the hollow sections on the backside, right?
http://inlinethumb32.webshots.com/97...600x600Q85.jpg
knifemaker87 Feb 10, 2011 09:53 AM
yeah.. i pulled the hub off and there is no way to get at the studs from the back-side. i talked to another honda guy and he said that they are threaded and i can weld a nut on them and spin them out. (i hope) gonna try that. i will keep you posted.
thanks!
~Chris
adrenalnjunky Feb 10, 2011 09:56 AM
yeah - I just found that - they're just threaded studs. looks like 12x25 threads - good news, replacements are cheap if you wanted to put studs back in after you machine the flange.
http://www.bikebandit.com/houseofmot...m2070#sch16541
adrenalnjunky Feb 10, 2011 10:00 AM
just on a tangent - I'm going to be trying to fit a F2 rear wheel to a 79 Yamaha XS 650 project I have cooking.
I'm relatively sure the stock swingarm on the XS is too narrow for this - do you know what width the F2 swingarm pivot is? I've found the XS needs something in the ~200mm range for a swingarm swap.
knifemaker87 Feb 10, 2011 10:10 AM
the pivot is about 9.31" or 236.4mm so.... it might be a tad big. but you could trim it down...
