Newbie here
Newbie here
Hey all. Going to look at and hopefully get a 94 f2 half basket case. Was told it was torn down for a repaint years ago and lost interest, but it's all there, but until I see for myself.. By the pictures it looks like all but the left rear of the plastics are there, and has the yellow wheels. If by chance the front end is not there, I thought I saw somewhere about swapping a different bikes front end on ?
Anything about these bikes I need to look for when I get there ?
Not sure if this is the help you are after but All ***** bearings has a list of bearings used in common fork seals. It might be a place to start.
HOWEVER, changing any component on any vehicle usually causes additional issues that will need to be addressed. Since you describe yourself as a newbie, by far the easiest thing is to use the stock front end, especially since F2 parts are so cheap. Then if, after the bike is together and working and you feel like modifying it you can go nuts changing stuff.
