OBD connection / Plug
Hi ,did have a Triumph that an OBD would connect to , but not on these , what you may need is this , if you want to go that far in , but just bridging the DLC will bring up the codes you will need, maybe with using a Power Commander 5 will help.
https://honda.snapon.com/HondaCycle/...temId=47541382
But quite pricey
But quite pricey
Hi matey, you'll need to raise the petrol tank, look for the DLC ,it should have a red cap on a 4pin connector, use a paperclip or piece of wire and bridge the Brown and Green wires,make sure the bike is on the side stand and in neutral and Kill switch on run, then turn on the ignition and watch the fi warning lights for codes for long and short flashes they are your codes
Cbr600F gear indicator
mate please tell me your talking about a cbr600F? I can not for the life of me find this dam plug for my indicator to go to. Any help much appreciated
