it won't run!
gotcha, i would try a compression check then, possibly a leak down to see if the valves aren't seating all the way.
when an engine sits for a long period of time, the open valves can form rust, and cause them not to seal up. this can show up in a compression test as low psi, squirt some oil in the cylinders to rule out the rings.
did you try spraying fuel, or starting fluid into the carbs?
