What rear tire sizes will fit?
RE: What rear tire sizes will fit?
Thanks. I acutally ended up going with a 140 Dunlop GT501. I had been looking to get another Battlax and finally got smart enough to look on their web site, which shows what tires will fit on what rims. Their widest was a certain 150, I think a 45 in an H rating. One of my dealer's mechanics recommended I not jump two sizes as it may really throw off the handling, said the 140 may mess it up. The 140 seems to be doing just fine and looks better than the 130. The next tire, I may try a 150, but will be sure to check with manufacturers to make sure whatever model is recommended for 3.5" rim.
If you change the swingarm, how do you get the sprockets to line up? You'd need to be getting the rear sprocket farther out to miss the wider tire and somehow need to get it to line up with the front. Sounds like more hassle than it'd be worth.
I AM CURRENTLY IN THE PROCESS OF SWITCHING OUT THE SWINGARM, RIM, TIRE, SPROCKET AND REAR SHOCK. I AM PUTTING A SWINGARM AND COMPLETE RIM(190 TIRE AND SPROCKET) FROM A 2002-2004 CBR F4I. I WILL HAVE TO MODIFY THE SWINGARM IN THE FRONT WHERE IT BOLTS TO THE FRAME, BUT EVERYTHING ELSE SHOULD BE FINE. IT IS ONLY 1/2 INCH WIDER ON EACH SIDE OF THE AXLE, BUT IS 1 1/2 INCHES WIDER IN SHOCK-SIDE. I WILL KEEP YOU POSTED ON HOW IT WORKS. I GOT EVERYTHING OFF OF EBAY AND ONLY SPENT ABOUT $125. THE COMPLETE RIM COST ME THE MOST(115). LATER-D
I am pretty sure F2/F3 stuff will not be too much trouble, the F4/F4i had aluminum frames and the width's are different, just make sure everything clears and does not bind up or it could cause major problems..
also the F41 has a 5.5" rim designed for a 180/55-17, a 190 may fit but I believe your bike will have so much rolling mass it may not turn very well
I ran a 150/70/17 Maxxis Supermax about 6 times and it profiled perfect. Any wider and I would question the profile of the tire plus and wider and it becomes extremely hard to mount the tire. I also ran a 120/70/17 on the front. Dont drop the series any because it doesnt profile well at all up front any shorter than a 70 series.
