what engine mods can i do?
Not to be an idiot or anything, but I would not waste your time on any extreme mods for the F. For the cost of them, youd be better off buying a more modern machine. However, some simple mods you can do are:
Carb Jets
Exhaust
K&N Filter
Ignition Advancer
Also you could Seafoam the engine to clear out the carbon deposits and clear up Lost power.
Now, i would seriously not recommend it, but you could have parts custom made, but they may not work at all.
Ie, custom ground cams, as well, I believe you can order Pistons from JE Pistons, but you need about 10 different measurements to do so. (Wiesco also does custom orders, but requires a minimum of 20 pistons i believe)
Carb Jets
Exhaust
K&N Filter
Ignition Advancer
