Turn signal problems
Ok I have no turn signals searched and so far nothing I've read has helped
here is the story got the bike about a month ago when you turn the key on the front light come on and the rears don't which is correct I believe But when you turn the switch either to the right or the left the front light goes out neither front or rear flash and there realy clicks as far as I can tell the fuse is good and all the bulbs are good the rears are new led signals not sure if that has anything to do with it or not any ideas would be great thanks |
The front bulbs are dual filament that is they have a filament for the running light and a filament for the signal check the bulbs to see that both are good there is also a fuse you might need to put a resistor in series with the new rear signals so they draw enough to operate the flashers
All filaments are good the fuse your talking about is it the one in the main fuse block if so that is ok and do you know what the resistance needs to be?
