tail section
RE: tail section
Well, I was initially going to try and do the undertail, however I did not want to go through the trouble of changing the swingarm to route the exhaust behind the right rear set. It may be possible to do it without a swing arm swap, but the routing of the pipe can be a real problem.
For example, here is an F2 with a properly routed mid pipe, and here is one on an F4i that is not so properly routed due to the S/A interference. I think it works, just looks damn ugly and if you are going to put that much work into a project, you at least want it to turn out nice.
RE: tail section
telgren you dont think that my plastics could hold up to the heat i think your may be right i am still looking for a way to do it i will probably run it like the f2 that rrasco posted i dont like the midpipe showing like the f4i has i might as well take my time and make it look good. thanks
