Stands?
Old 01-22-2007, 01:39 PM
rrasco's Avatar
Default Stands?
I was about to order some stands and I want to make sure they will work. For the front stand, does the F1 have the holes in the bottom of the forks?
http://www.handyindustries.com/shop/...mp;D=1&S=4
Old 01-22-2007, 01:47 PM
Default RE: Stands?
I had a pair of these and they worked good. I did not realize they had the bobbin attachment before I sold them but will probably buy them again as they do actually work really good.
To answer your question, I believe it does have the holes in the bottom. I didnt have stands when I had my Hurricane so I dont remember for sure, but I'll bet it does. If not, you can buy the expensive front end stands (steering stem inserts) or the ones with the rubber pads that grab the forks.
Old 01-22-2007, 01:55 PM
rrasco's Avatar
Default RE: Stands?
i would like to get the handy stands, if not ones like these?
http://tinyurl.com/33hqdz
Old 01-22-2007, 03:19 PM
Default RE: Stands?
I like the design of the front one, but the rear looks very cheap and ricketty to me.
Old 01-22-2007, 03:22 PM
michigan_313's Avatar
Default RE: Stands?
i've gotpitbull front and rear stands.
Old 01-22-2007, 05:31 PM
rrasco's Avatar
Default RE: Stands?
how do they hold the forks up? do the forks have the hole on the bottom?
Old 01-23-2007, 12:54 AM
Default RE: Stands?
there are 2 different front stands from pitbull.
one uses the steering head and the other cradles the bottom of the forks. 87-90 do have holes on the bottom of the forks. my preference is to lift the front from the steering head tube.
Old 01-23-2007, 01:23 AM
rrasco's Avatar
Default RE: Stands?
you are talking about this type right?
http://preview.tinyurl.com/ywhvgf
i was probably going to buy ones for the holes cause they are alot cheaper but i wanted to make sure they would work. i also was not aware the F1 could use the steering head, if im correct on what it is.
Old 01-23-2007, 03:22 PM
Default RE: Stands?
i don't know of too many bikes that can't be lifted from the steering head. but the f1 sure can. just remove the horn and that's it.
check this pitbull link, they have good pics of various front stands.
http://www.pit-bull.com/catalog/inde...d1d9f633674e4e
lifting from the steering head, by that i mean there is a hole under the bottom triple clamp that is used, or to say it another way, the steering tube is hollow.
if you plan on using the front stand only, make sure the bike will not have a tendency to roll back.
Old 01-23-2007, 03:39 PM
drakito's Avatar
Default RE: Stands?
Check these out, good priceand everything.
http://cgi.ebay.com/ebaymotors/Honda...ayphotohosting
Quick Reply: Stands?
