Rear wheel bearings
Old May 27, 2022 | 09:35 AM
IronFistChaplain's Avatar
Question Rear wheel bearings
Good morning fellow CBR folks, I have an 89 Hurricane and I am fixed my rear wheel, well the bearings, had an incident not too long ago where the sprocket bearing just yeeted and left the wheel in pieces, well, I have the other bearings replaced but the spocket bearing, it doesnt sit flush, still a quarter of it sticks out, is that how its supposed to be? I have no idea honestly. because it cannot go any farther in due to the inner spacing or rather build of the wheel prevents it.
Old May 27, 2022 | 02:26 PM
Can you post some pictures of what you're seeing? It doesn't sound correct.
Old May 27, 2022 | 02:40 PM
Sure, once I get home, I will.
Old Jun 5, 2022 | 04:27 PM
These are the photos, is that the outer ring of the bearing that blew apart? or what/
Old Jun 5, 2022 | 10:47 PM
cbrbike's Avatar
it looks like outer race of your old bearing is still stuck inside that bore. you may need to remove it first and then drive the new bearing in.
Old Jun 5, 2022 | 11:04 PM
I've tried countless time's and just cannot get that race out for anything. I've beaten at it/carefully avoiding damaging the inside of the hub, I just don't know what to do now cause it will not budge.
Old Jun 6, 2022 | 02:00 AM
cbrbike's Avatar
hi. i think you need to take it to a machine shop. they will remove it for you.
Old Jun 22, 2022 | 08:19 PM
stanthomas's Avatar
Bit late maybe but I've just replaced the bearing in my sprocket carrier. I found that by heating the carrier to 100 C or so the bearing will drop straight out. Maybe help it by banging down on the bench. I used a blow torch but dunking in boiling water would work just as well to get it out.
Old Jun 22, 2022 | 10:26 PM
@stanthomas Thanks for posting back on how you got it resolved. Now back on the ride again.
CPH007
May 27, 2022 12:52 PM
dyracuse
Apr 15, 2010 04:51 PM
MikeInCtown
May 29, 2008 09:44 AM
Eckl
Jan 1, 2008 08:32 PM
