R&R gaskets on 89 CANE any pointers?
Old Apr 18, 2012 | 08:15 PM
89HurricaneF1's Avatar
Default R&R gaskets on 89 CANE any pointers?
I removed the engine from my 89 Cane to replace all of the gaskets due to an oil leak that i believe may be coming from the cylinder head.... Anyways since i am replacing all gaskets and dont want to have to remove the engine again.... i was curious if there are any other things that i should replace while i have engine out... also any pointers or things to look for.. common wear items etc.... Thanks everyone...
Old Apr 20, 2012 | 12:41 AM
87 cbr 600f's Avatar
Default items to check
u may want to check ur cct ,valve clearance
Old Apr 20, 2012 | 07:15 AM
What am I looking for with the CCT? I'm guessing that means Cam Chain tension? Also specs.for valve clearance? Thanks
Old May 3, 2012 | 12:59 PM
Default checks
the valve clearances are.....inlet valve 0.14-0.18 and the exhaust valve is0.18-0.22.. assuming u have a cbr 600 if urs is a 1000 message me and i can give u the 1000 specs..yes cct is the cam chain tensioer they can be weak also check u dont have the dreaded crack in the frame.lh side around engine mounts
Old May 3, 2012 | 01:06 PM
Default cbr manual
here is a link so u can gat a manual if u dont have one Motorcycle Honda CBR600F1 Repair Manual Download
Old May 3, 2012 | 02:28 PM
Appreciate all the good tips, I'm having an issue with two cylinders firing and two not firing now.... I put a thread up if ya wanna read it, it goes more into detail.... I'm running out of options....
FSUNOLES
Street Skills
Mar 27, 2013 10:26 AM
magnumRT
Sep 7, 2012 02:16 AM
IDoDirt
Oct 13, 2011 03:30 AM
latinonino04
Apr 17, 2009 08:39 PM
rollin_deist
Apr 1, 2008 10:33 PM
