power sourse
Old Apr 27, 2013 | 01:48 PM
Zachbw55's Avatar
Default power sourse
Hey guys what wires can I tap into for a 12 volt power sourse? I need it to only have power when the bike is running
Old Apr 27, 2013 | 06:00 PM
CorruptFile's Avatar
June 2013 ROTM
What do you need to run?
Old Apr 28, 2013 | 10:52 AM
MadHattr059's Avatar
If you're not needing a lot of current (ie gps,phone,mp3),
easiest is a tap to the hot on the tail-light/license plate circuit. It's a switched circuit.
If you're wanting to pull more current than that (extra running lights, heated gear, etc),
you should go with a relay with the high-end tied to the battery (with an inline fuse)
and the low-end tied to the same tail-light circuit, as mentioned above (to enable switching).
Ern
Old Apr 30, 2013 | 04:00 PM
Zachbw55's Avatar
Yeah I'm running a phone and GPS.
Old Apr 30, 2013 | 04:13 PM
June 2013 ROTM
There is a brown wire for a position lamp, which as fat as I can tell, doesn't exist. You can tap into that. It is switchable with the ignition.
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
