Next bikes gonna be fuel injected hate carbs
Ok guys. Got my carbs clean. Not once or twice, id say ive had them off 5 times now. Anyway there is somthing up.
In the morning she will idle fine . after a short drive , whenstoped at a trafic light the idle will begain to jump up and down . If I do not blipthe throtle the bike will stall. Riding it works fine, Exceptit will bog some times at 4000 - 4500 rpm? Has anyone else have this happen?
RE: Next bikes gonna be fuel injected hate carbs
dude i had the exact same thing happen i pulled the carbs and put them back on probably at least 15 times and still didnt get it right i replaced the carbs and havnt had a simgle problem since. also check that on the number 2 cylinder that there is a air inlet of sorts and a hose connects it to the carburators i fixed that when i replaced my carbs with a used set and havnt had a problem since. did the bike work before you pulled the carbs or was it the same story then and thats why you tried to clean them.
hope that this makes some sense
Ryan
Ryan
jordan
07-24-2006 06:39 PM
