New motor wont run!!!
Old Jun 29, 2009 | 02:02 PM
reeseychez's Avatar
Default New motor wont run!!!
88 Honda Hurricane.
I spun a bearing on my last motor and in stead of splitting the cases. opted for a used motor off ebay.
got the motor in and fired it up, ran for a little while but sounded way off. almost like more of a V-Twin than an inline four. i shut it down and did some more work
replaced spark plugs
cleaned carbs
now im worried my timing may be off or maybe i just hooked up the spark plugs wrong
any ideas???
Old Jun 29, 2009 | 04:15 PM
Measuredpath's Avatar
How about you follow your thoughts and check the timing and spark order?
Old Jun 29, 2009 | 04:57 PM
reeseychez's Avatar
how do i check the timing? can it be adjusted without having to remove the engine from the frame?
Old Jun 29, 2009 | 10:01 PM
STBrider91's Avatar
I dont know if this will help but i have a f2 and the timing on that cant be changed its automatic but i dont know if its the same for your bike but thought i'd throw that out there good look
Old Jun 30, 2009 | 06:13 AM
KongBastard's Avatar
I would start with the basics like making sure you have spark on all plugs, that you have the firing order correct, battery is good, all connections tight (and correct).
I am not sure how to set the timing (download a manual) but I doubt that somebody is going to bugger around with the timing and then sell the motor.
Sound electrical to me
KongBastard
Old Jul 1, 2009 | 10:28 PM
Billistic's Avatar
Timing can be checked but not adjusted.
Yes, download the manual.
C Jacob W
Jul 29, 2013 11:03 AM
600F4inoober
Jun 7, 2010 01:30 PM
tagger609
Jun 27, 2008 02:09 PM
mishab
Sep 7, 2007 01:00 AM
Billy Boots
Apr 4, 2007 04:50 PM
