Need help whit getting my bike inspected
The problem is my bike has no speedo or speedo cable, I am wondering if I can replace it with one from a any other bike or if it has to be from a hurricane. Second I need a headlight that can be switch from hi/lo. The bike does not have the stock headlight, It curently has one of those street fighter headlights(the ones that you see on stuntbikes) directly wired to the battery. Im pretty sure I can wire it in to the hi/lo switch and make it work but the wiring is pretty jacked up and I can find a wiring diagram to help out.
you can use any speedo that is driven by a cable. so any analog speedo will work. problem will be the accuracy of the speedo depending on what model it came from. you might be off little or a lot.
light housing doesn't matter as much as the bulb you use. as long as the bulb is a double filament, hi and lo, you can use any light housing that will accomodate it. if you don't have a fairing stay or fairing, then i would consider using a round headlight from another model bike and using brackets to mount it to the forks. wiring it up into the left control switch shouldn't be a problem.
