need help with projector headlight
tested stock wiring the other day and found my ground/hi/lo. they both worked with the key on. i also tested the headlight i got with a 9v battery and it lit up (dim but it was just to test it). after i wired it into the stock harness it didnt work.
i then tested the light again and it worked. and then tested the harness again and it didnt show power coming from the hi or lo. now im kind of at a stand still with it. im about to go rip the bike apart to change my plugs, ill take pictures if thatll help the headlight is a single beam projector. h3 i believe. could i have blown a fuse or something? is the light compatible with the bike? |
I would say you definetly blew a fuse
How do you have it wired up?
If it's a single-beam with H3 bulb, you should connect only the low-beam power-line to it. The high-beam should be disconnected. If you had a bi-xenon projector, then the high-beam line would connect to the solenoid that flips up the shield. Look up the wiring-diagram and find the fuses for low & high beam circuit. You may have blown both of them. |
| All times are GMT -5. The time now is 07:47 AM. |
