My new project
2 Attachment(s)
I picked up a 88 cbr600 today. It needs some work but it runs good. The only problems I discovered so far is that the rear brakes sticks. How do you fix that? Also looking for a tank and fairings if you know of any.
Attachment 83943 Attachment 83944 |
RE: My new project
Rear Brake: Take it apart!
Seriously, take the caliper and rotor off the bike. make sure that the rotor is true and thick enough. Then disassemble the caliper as far as you can, and try to get the piston out. Sometimes the seals in there go bad or you get some corrosion that interferes with the piston's movement. You might need new seals, but you definitely need to clean out any gunk. |
RE: My new project
ah who needs a rear brake!?!?!
id, give hurricanes advice a try, whatever you do, dont put wd40 on it though....lol. |
RE: My new project
I have a tank it is black and has no cap and is a little dented. I will post a photo.
RE: My new project
I'll let you know when I see the pic if I'm interested. How much are you wanting for it?
RE: My new project
here it is cheap has cap nd petcock after all cheap 40 dollars yocan't see the dent in the picture. I will take another one in better light tomorrow it definately needs repair
RE: My new project
looks good enough to me, right now I only care about it running. I'll make it good looking later. Do you happen to have the key for it? Is it rusty inside? Do you happen to have any more parts. I need the right rear fairing and possible a reaer brake caliper. I haven't had a chance to check mine out yet but if you got a good one let me know. Shoot me an email to bigfranks84@gmail.com with payment details.
RE: My new project
I've got a rear brake unit from an F3. I'll take a look at it and see if they are interchangable. Does anyone on here happen to know offhand?
RE: My new project
no, not without some work.
1. the caliper will not fit right up since the bolt spacing does not match the f1 caliper bracket bolt spacing. 2. the f1 caliper bracket is backed by a brake torque arm. the f3 uses a stop welded on the inside inner surface of t he swingarmto keep the caliper bracket from moving or twisting instead of the torque arm. 3. the f1 rear axle assembly (axle bolt, spacers, swingarm, caliper bracket) is 15mm diameter. the same assembly on the f3 is using 17mm dia. axle bolt. 4. i cannot remember offhand, but i believe the spacing between rim spoke to outside edge of rim is a narrow fit for the f3 caliper. since the f3 caliper is wider, it may impinge on the spokes. |
RE: My new project
took my caliper apart and cleaned it. doesn't seem to be sticking any more. thanks guys. once i get a tank i'll get this thing running again. I need to change the oil and I'll prob flush the coolant while i'm at it sense its probably way old.
