Mods for a hurricane, I have some, but need more.
if the front end is bottoming out it could be either springs or oil or both. you should not hit a bump and feel the front end slamming. that's an accident waiting to happen.
for internals you could get heavier springs and emulators. that would prevent the forks from bottoming out and provide smoother fork action.
performance mods at this point are down to port and polish, and cylinder boring.
unless you plan on riding in a straight line, you should have a suspension to match your engine performance.
ORIGINAL: OLDbutFAST
The timing advance works great!! they also make a shift star kit along with a shift detent kit. I have all 3, they are relitively inexpensive and make a big difference.
Has anyone ever put diffrent cams in? cylinder port and polish how much does it help? I just want to hang better with the newer 600's
factory pro on all three.
i do not know of any different cams that can be put into this engine.
port and polish will help some but if you are going to go through this much trouble "to hang" with newer 600s then i would just get the cylinders bored out.
you can hang with the newer 600's JUST FINE on the Hurricane, just upgrade your tires and suspension, and stay in the twisties, where bikes are supposed to be. straight line sucks and isnt what a sportbike is built to do.
what you need to do, is improve your riding skills more and you will then become a better rider. trackday trackday trackday. you'll find in the twisties then that you'll be able to hang with ANYTHING, from the 250's to the 1000's.
